Use the following process to schedule a recording from the Contour app or from WatchTV.cox.com that can be viewed from the receiver within your home.
Flash is no longer required for watchtv.cox.com with any browser.
Access and sign in to one of the following viewing options.
From the For You window, based on the type of device you are using, complete the following.
Note: The All Channels option displays all channels within your subscription. Some channels are available only within the home. For channel information, refer to Viewing Programs Using the Contour App.
If viewing from... | Then... |
The Contour app |
WatchTV.cox.com | Click Live TV and then select All Channels. Result: All the channels in your subscription display. |
Locate the channel or program.
Complete the following to select and record the TV program.
From the pop-up window, complete the following.
