• Shopping Cart
Setting a Parental Control PIN With a Mini Box
Parental Controls allow you to control who watches certain TV programs. You can lock programs by rating or block whole channels so they cannot be viewed without the Parental Control PIN.
  1. Press the COX MENU button to display the Menu.
  2. Use the ARROWS to highlight Settings. Press SELECT.
  3. Parental Controls are now highlighted. Press SELECT.
  4. Use the ARROW buttons to highlight Set Parental Control PIN and press SELECT
  5. Use the NUMBER keys to set a four-digit PIN.
  6. You will need to re-enter the same four-digit PIN.
  7. The Parental Control PIN is now set.
  8. Press SELECT to clear the confirmation message.
