Using the Cox remote, press the SETTINGS button and then the A button.
Complete the following steps.
In the image below, see the current settings for each column.
To change a setting, use the right arrow key to begin the selection process then use the arrow keys to select the change, and then press SELECT.
Press the EXIT button.
