• Shopping Cart
Selecting Audio Settings for a Contour Receiver
On the Cox remote, press MENU to open the Contour from Cox menu.
Use the down arrow to highlight Settings and then press the right arrow.
Image of Contour menu highlighting settings
Result: The Settings menu displays.
Use the down arrow to highlight Audio & Video and then press the right arrow.
Image of Contour Settings menu highlighting Audio and Video
Use the down arrow to highlight Audio Settings and then press the right arrow.
Image Contour Audio and Video settings highlighting Audio Setting
Use the table below to determine which audio setting to select.
Audio Settings Options
Volume Level Volume Level enables or disables the ability of the Cox Remote to adjust the volume on the TV.
  • If you select Variable, then the Cox Remote can control the volume on the TV.
  • If you select Fixed, then the Cox Remote cannot control the volume on the TV.
Analog Output
Analog Output controls the audio output sent to your TV from the receiver.
Note: This option is not available if the receiver is connected to the TV using an HDMI cable.
  • Mono uses one signal for sound. The quality of sound is generally lower with this setting.
  • Stereo uses multiple signal for sound. The quality of sound with this setting is higher than Mono.
  • Surround Sound is used if you have surround sound equipment.
Digital Output Digital Output is used to enable sound through an optical jack.
  • Pulse Code Modulated converts analog audio signals into digital audio signals.
  • Dolby Digital (AC3) is used for Dolby digital sounds available on certain digital broadcasts and streaming video.
Dynamic Range Dynamic Range is the difference between the quietest and loudest volume in a stream. In modern recording, this range is often limited through dynamic range compression, which allows for louder volume, but can make the recording sound less exciting or live.
  • Narrow dramatically lowers the higher volumes
  • Medium slightly lowers the higher volumes
  • Wide plays the entire audio dynamic range, including and highest and lowest sounds
    Note: Wide offers the greatest variance and higher quality of sound but a possible lower volume setting.
Audio Language Audio Language selects the audio language for programs that carry both the primary language and Secondary Audio Programming (SAP).
  • Primary will always use the primary language.
  • Alternate (SAP) will use the SAP when available.
