Contour receivers can be put on standby to reduce power usage without affecting scheduled recordings. Power saver mode can be activated at any time by saying “power down” into the Voice remote or by performing the following steps.
Press the CONTOUR button to display the Main Menu.
Use the arrow buttons to highlight the gear icon, and then press OK.
Use the down arrow to highlight Device Settings, and then press OK.
Use the down arrow to highlight Power Preferences, and then press OK.
The below table provides the different available power save options.
Options | Steps |
Power Saver | Use Ok button to toggle On / Off. Note: The receiver powers down when the TV is turned off. |
Power Down Now |
Restart |
Note: This action turns the receiver off and then back on. |
Review the following regarding the Power Save feature.
