• Shopping Cart
  • View Cart
Configuring Door Chime Sound Settings
Select a unique door chime for when the selected door is opened or closed, or silence the chime all together. You can choose sounds ranging from simple chimes or beeps, fun sounds like a Rooster Call or Crowd Applause, to safety sounds like a Dog Barking.
Follow the steps below to set the tones that are heard when a door or window is opened or closed.
On the touchscreen home screen, tap Settings.
Enter the Master Code to proceed to the Settings menu.
From the Settings menu, tap TouchScreen.
Tap TouchScreen
From the TouchScreen menu, tap Sound Configuration.
Tap Sound Configuration
From the Sound Configuration menu, tap Hometone Configuration.
Tap Hometone Configuration
The screen displays allowing you to set the tones for each zone in your system.
Note: The zones displayed vary based on your system setup.
  1. To set the tone made for a zone when it is opened, tap the field next to the red icon for that zone.
    Zone Settings for Open
  2. Scroll through the list on the Select Zone Fault Tone screen to see the tones available. Tap to select a tone from the list provided.
    Select Zone Fault Tone Screen
7
  1. To set the tone made for a zone when it is closed, tap the field next to the green icon for that zone.
    Zone Settings for Closed
  2. The Select Zone Fault Tone screen displays. Scroll through the list to see the tones available. Tap to select a tone from the list provided.
To have a zone never make a sound, tap Silence for that zone. You may also select None on the Select Zone Fault Tone screen.
Image of 2 Chat Bubbles
Need More Help? Let's chat!
Chat live with a Cox agent to get the fastest answers to all your top questions.
Modal Id: ttps:--www.cox.com-residential-modals-support-call-_jcr_content-parcontent-sectioncontainer.html
