A phone jack uses your home wiring to provide a dial tone to additional phone devices. Use the steps below to connect your phone equipment to a wall jack.
Locate an available phone wall jack.
Disconnect the phone equipment from Tel2.
Connect the phone equipment previously connected to Tel2 to the available wall jack.
Confirm there is a dial tone. If you are using a fax machine, send a test fax.
The image below displays how to use the wall jack to connect phone equipment to Tel1.
