Use the steps below to use a 2-Way RJ11 Splitter to connect phone equipment to the Tel1 modem port.
Note: The 2-Way RJ11 Splitter can be purchased from your local home supply store or online.
Disconnect the phone equipment from Tel1.
Connect the 2-Way RJ11 Splitter to Tel1.
Connect the phone equipment previously in Tel1 into one of the ports on the splitter.
Using the handset, confirm if there is a dial tone.
Disconnect the phone equipment from Tel2 and connect to the available port on the splitter.
Using the handset, confirm there is a dial tone. If you are using a fax machine, send a test fax.
Note: If you experience issues, contact us for assistance.
The image below displays how to use the 2-Way RJ11 Splitter to connect phone equipment to Tel1.
