Setting a Parental Control PIN with a Non-DVR Scientific Atlanta / Cisco Receiver
Before any blocks can be set, a PIN must be enabled to prevent unauthorized changes. Follow the steps below to personalize your Parental Control PIN.
  • The default Parental Control pin is 0000.
  • If you forget your PIN, the account holder must contact Customer Service to have it reset.
Press the SETTINGS button on the remote.
Press the A button to access the General Settings Menu.
Using the UP or DOWN arrows, select Block: PIN.
Press the SELECT button.
Using the UP or DOWN arrows, select Enable and press the SELECT button.
Enter a four-digit PIN number to enable Parental Controls.
7
Re-enter the four-digit PIN to confirm that it was entered correctly.
After setting the four-digit PIN, the current status of the Block:PIN changes from Disabled to Enabled.
Didn't Find What You Were Looking For?  Search Here.
