Connecting a Bluetooth Device With Your Contour Wireless Xi6 Receiver
Using the remote control, complete the following to access the Bluetooth menu.
  1. Press the Contour button.
  2. Press the Mic button and say, "Bluetooth."
From the Settings menu, complete the following.
  1. Press the down arrow button to highlight and select Device Settings, and then press OK.
  2. Arrow down to select Audio, and then press OK.
    Image of Audio Device Settings Menu
  3. Arrow down to select Bluetooth Devices, and then press OK.
    Result: Bluetooth devices that are in pairing mode display.
     Image of Device Settings Bluetooth Devices
From the list of devices, select your Bluetooth device, and then press OK.
Image of Connecting Bluetooth Devices in Bluetooth Settings
Image of device name in Bluetooth settings
Result: The Bluetooth device is now connected with the Wireless 4K Contour Stream Player.
Image of Connected Device in Bluetooth Settings
Note
: The below screen displays if pairing fails. Refer to the device instructions.
Image of failed pairing in Bluetooth settings
